sorry about the double thread but the other has been weared out and this one is specific
Hi, I came across a free :D almost new s14 jb flywheel used on an sports evo for only months, but:
S14`s FW: weight: 8lbs... clutch: 228mm
M30`s FW: weight: 11lbs clutch: 240mm
M20`s: ........................ clutch: 228mm
Knowing you can use the M10`s flywheel you should be able to use the s14`s too (not sure) as also the gearbox. So my questions are
1._ Does the S14`s flywheel fit the M30 with no problems, specially STARTER related ones!!!!!!! :hitler:
2._ Is 8lbs to light for the M30? (going turbo 8psi after the FW job)
3._ Can I use the M20`s double mass FW clutch setup on the s14`s flywheel being both 228mm?
If it all works ill post videos of the car without turbo so you can see the revs response and idle issues if any. may be a good option and the m3`s FW is cheaper by almost $100.
Thanks soooooooo Much!! :-D
HandalE30
HandalE30
I guess its not a common question. thanks spinning tires.
